Pixhawk Cube Dual Battery Configuration
Hello all,
I will use 6s LIPO 5000mah X 2 and I’m scared to burn the battery or drone when I connect the power.
I heard that configuration “2” is the best.
but, I have 2 battery monitors and I dont want configuration “2” because I have to buy or make “Y” cable.
I do not want to make “Y” cable.
is it possible to use configuration “3”?
will there is no problem? I will connect “battery monitor 1” to “pixhawk cube connector power 1” & “battery monitor 2” to “pixhawk cube connector power 2”
Im planning to lift up heavy things so current draw will be severe. will this doubling battery monitor help me?
yes, 3 is possible and also the best solution. But remember: the battery voltages are not independent.
3 will work but you will have to set battery current mode to add up the current from the pair of sensors and average the voltage to get a correct reading
so
batt1 setting would be 10 Sum Of Selected Monitors
batt2 would be power sensor 1 and power sensor 1 current
batt3 would be power sensor 2 and power sensor 2 current.
https://ardupilot.org/copter/docs/common-power-module-configuration-in-mission-planner.html#other-parameters
This may be of interest to avoid imbalances, though it doesn’t necessarily/specifically address power redundancy.
