I am using Pixhawk cube. there is a built-in ads-b receiver. but there is no transmitter. how do i set up an ads-b transmitter ? What should I do to see my own plane on the flightradar24 ? There is a squawk code in the parameter list, I think I can broadcast ?
The cube orange is only an ADS-B receiver. It does not transmit. Transmitting ADS-B messages requires approval or at least guidance from your countries aviation authority.
You won’t be able to see your plane on Flightradar24 unless your country allows you to broadcast ADS-B.
Edit: I should add, that if you do have approval to broadcast ADS-B out, you’re going to need to install a transponder such as: https://uavionix.com/products/ping200x/.
image every orange cube transmitting that 10’s thousands around the world clog up the network
