yeah, the data cable could be the problem. But if all else fails, I think I read somewhere that the params are stored on the SD card, maybe they could be extracted from it?
The other pixhawk you tried on the same computer right? It could be a driver issue. Also check that the baud rate is 9600 when connecting. Also, have you tried to read the parameters over a telemetry (like wireless/ radio telemetry modules). It could work then. Also, try the “Auto” setting when connectiing (I’m suspecting this might be something to do with the connection settings).
HUD 16 hz drawtime 1 gl True
bps 3526 loss 541 left 111 mem 33.4951171875 mav2 False sign False mav1 118 mav2
0 signed 0
INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (Len Fail) len 20 pkno
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 224 exp 223 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 244 exp 243 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 4 exp 3 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - Get param 1 by 1 - got 0 of 1
INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (crc fail) len 33 crc
8218 vs 776 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 22 exp 21 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 25 exp 24 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:53 م 2 PreArm: Bad GPS P
osition
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 48 exp 47 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 59 exp 58 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 78 exp 77 pkts lost 1
HUD 17 hz drawtime 1 gl True
bps 3521 loss 549 left 0 mem 34.142578125 mav2 False sign False mav1 118 mav2 0
signed 0
INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (Len Fail) len 20 pkno 51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 89 exp 88 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (crc fail) len 33 crc 56923 vs 64841 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 97 exp 96 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 109 exp 108 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 125 exp 124 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 145 exp 144 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:54 م 2 PreArm: Bad GPS Position
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 168 exp 167 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - Mavlink Bad Packet (crc fail) len 33 crc 17809 vs 26243 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 177 exp 176 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 183 exp 182 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 199 exp 198 pkts lost 1
bps 3359 loss 558 left 0 mem 34.5751953125 mav2 False sign False mav1 112 mav2 0
signed 0
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 215 exp 214 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 229 exp 228 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 250 exp 249 pkts lost 1
22341 vs 29783 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 252 exp 251 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 9 exp 8 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:55 م 2 PreArm: Bad GPS P
osition
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 33 exp 32 pkts lost 1
51
INFO MissionPlanner.Controls.HUD - Was in onpaint Hud th:Base Thread in Base Thr
ead
bps 2717 loss 564 left 5786 mem 33.326171875 mav2 False sign False mav1 90 mav2
0 signed 0
ead
HUD 16 hz drawtime 0 gl True
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 47 exp 46 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 68 exp 67 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 79 exp 78 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 98 exp 97 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 114 exp 113 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 128 exp 127 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:57 م 2 PreArm: Bad GPS P
osition
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 151 exp 150 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 165 exp 164 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 187 exp 186 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 206 exp 205 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 217 exp 216 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 238 exp 237 pkts lost 1
19823 vs 28285 pkno 22 PARAM_VALUE
61339 vs 52361 pkno 22 PARAM_VALUE
55977 vs 63931 pkno 22 PARAM_VALUE
21549 vs 30527 pkno 22 PARAM_VALUE
56071 vs 63509 pkno 22 PARAM_VALUE
42133 vs 34695 pkno 22 PARAM_VALUE
188 vs 9134 pkno 22 PARAM_VALUE
44524 vs 36606 pkno 22 PARAM_VALUE
3694 vs 11644 pkno 22 PARAM_VALUE
59379 vs 50401 pkno 22 PARAM_VALUE
56012 vs 63966 pkno 22 PARAM_VALUE
5229 vs 14207 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 255 exp 243 pkts lost 12
39991 vs 48933 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 1 exp 0 pkts lost 257
HUD 1 hz drawtime 9 gl True
51
51
osition
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 42 exp 41 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 63 exp 62 pkts lost 1
bps 8032 loss 582 left 120 mem 33.5810546875 mav2 False sign False mav1 261 mav2
0 signed 0
65389 vs 56447 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 81 exp 80 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 84 exp 83 pkts lost 1
HUD 10 hz drawtime 2 gl True
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 100 exp 99 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 116 exp 115 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 130 exp 129 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 146 exp 145 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:58 م 2 PreArm: Bad GPS P
osition
46614 vs 38148 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 159 exp 158 pkts lost 1
51
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 185 exp 184 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 204 exp 203 pkts lost 1
bps 3491 loss 592 left 0 mem 34.267578125 mav2 False sign False mav1 115 mav2 0
signed 0
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 220 exp 219 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 240 exp 239 pkts lost 1
6442 vs 14904 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 242 exp 241 pkts lost 1
51
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 17 exp 16 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:34:59 م 2 PreArm: Bad GPS P
osition
51
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 49 exp 48 pkts lost 1
41369 vs 33419 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 67 exp 66 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 70 exp 69 pkts lost 1
bps 3437 loss 601 left 91 mem 34.6875 mav2 False sign False mav1 114 mav2 0 sign
ed 0
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 86 exp 85 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 105 exp 104 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 127 exp 126 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 138 exp 137 pkts lost 1
2619 vs 10537 pkno 22 PARAM_VALUE
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 140 exp 139 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:35:00 م 2 PreArm: Bad GPS P
osition
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 160 exp 159 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 171 exp 170 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 190 exp 189 pkts lost 1
bps 3453 loss 609 left 197 mem 33.3505859375 mav2 False sign False mav1 117 mav2
0 signed 0
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 207 exp 206 pkts lost 1
26977 vs 19059 pkno 22 PARAM_VALUE
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 227 exp 226 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 248 exp 247 pkts lost 1
51
INFO MissionPlanner.MAVLinkInterface - mav 1-1 seqno 6 exp 5 pkts lost 1
INFO MissionPlanner.MAVLinkInterface - 24/06/2019 10:35:01 م 2 PreArm: Bad GPS P
osition
Any explain what happen with the mavlink interface ??
Mission planner is receiving data from the pixhawk when you connect. It will ten ask for the parameters. However, if this request doesn’t reach the pixhawk, nothing happens.
Which means, TX from pixhawk to RX from PC is working, but TX from PC to RX from pixhawk isn’t.
I have seen this happen before due to a mismatch in the logic level of the hardware. Since I use the pixhawk 2.1, I always use a buffer to bring the levels from 3.3 to 5V.
