Hi there,
can anybody help me with this problem I have after I move from quad to hexacopter? Namely, I armed the drone and after couple of sec it has been disarmed by his own…I don’t know what could be the reason.
Everything is connected as it should be…i have 13 satelites locked…excellent signal…I have manage to lock and start to fly but after couple of seconds drone unlock and try to RTL…
I have log file I’m sending below. What have I done wrong?
Log File C:\Users\igork\Documents\Mission Planner\logs\HEXAROTOR\1\145 05-Jul-20 18-53-28.bin.log
Size (kb) 1284.7587890625
No of lines 16648
Duration 0:00:44
Vehicletype ArduCopter
Firmware Version V4.0.3
Firmware Hash ffd08628
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (16.28%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_BATT
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.38, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = WARN - Motor channel averages = [1298, 1350, 1368, 1273, 1312, 1337]
Average motor output = 1323
Difference between min and max motor averages = 95
Test: NaNs = FAIL - Found NaN in BAT.Curr
Found NaN in BAT.CurrTot
Found NaN in BAT.EnrgTot
Found NaN in CTUN.DSAlt
Found NaN in BAT2.Curr
Found NaN in BAT2.CurrTot
Found NaN in BAT2.EnrgTot
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
Thanks!
