Pixhawk 6C not connecting via UART to companion computer through MAVLink nor ROS2
Current Issue:
  • Pixhawk 6C Flight controller board cannot make serial connection to companion computer over MAVLink nor UXRCE_DDS
My Setup:
  • Setup 1 (Proved to be able to connect):
FC Board: Pixhawk 1, also known as pixhawk 2.4.8
Companion Computer: Orangepi 5 max dev board
Connection: Telem2 on FC board, UART pins on Orangepi dev board
Performed actions:
  • MAVLink connection proved to be up, on serial port /dev/ttyS1 of Orangepi dev board;
  • UXRCE connection proved to be up, MicroXRCEAgent have output showing topics were created;
  • Can echo and post topic using ROS2
  • Setup 2 (Proved to have issue):
FC Board: Pixhawk 6C or Pixhawk V6C
Performed actions:
  • MAVLink connection down, double checked parameters MAV_1_CONFIG=102, UXRCE_DDS_CFG=0, SER_TEL2_BAUD=57600;
  • UXRCE connection down, double checked parameters MAV_1_CONFIG=0, UXRCE_DDS_CFG=102, SER_TEL2_BAUD=921600.
Observation:
In MAVLink console I can see uxrce_dds_client is running but in default is on udp
When I manually start uxrce_dds_client on it’s telem2 port(/dev/ttyS3) it’s waiting for connection, but when I wire it up with Orangepi dev board and start mavproxy.py or MicroXRCEAgent both methods of connection have no reply.
Conclusion:
  • Pixhawk 1 is able to establish connections with Orangepi dev board so the method should work.
  • Assuming that I’ll need aome sort of logs to clear things up, or some tinkering on the 6c board if it’s a known issue, but have no clue.
Please advise
Which versions are you using?
tried with 1.15, 1.14, 1.13, still no luck on the 6c board
what info should I provide?
Ardupilot 4.4.x or Ardupilot 4.5.x or Ardupilot 4.6.x
I did not ask the mission planner version. From mission planner you MUST use the latest version at all times.
Thanks for your help, I’ve just realized that I should post it on PX4 forum instead of Ardupilot forum.
:skull:
This topic is now moving to:
