I’m setting up a new pixhawk 6c on an airplane and after doing all the basic setup, loaded firmware, calibrated radios, etc. I’m not getting any movement from the servos which are connected to the FMU PWM Out plug on the 6c. The main motor with the prop is connected to Ch 3 on the I/O PWM Out plug and spins to full power when armed.
FMU PWM Out Ch 1 is aileron, Ch 2 is elevator, ch 3 is rudder (these are servo outputs 1,2, & 4) in APM. +5v in connected to ch 8 on the FMU PWM plug output rail for power, measuring 5v at all of the power pins.
Safety switch has been disabled with BRD_SAFETY_DEFLT = 0 (agin the prop spins so I can rule this out). Attaching a log file for reference.
I have seen some similar posts, but no resolutions in any of them. Any help troubleshooting would be great.
2024-04-14 17-29-03.tlog (174.7 KB)
