I just flashed my Pixhawk 4 with Copter 3.6.1 using Mission Planner. However, when I connect the battery to my power module, I don’t get a voltage reading. I wired up my Pixhawk properly according to this Document. I have also read this article about how to set power modules in Mission Planner. Here is what my screen looks like, indicating no voltage readings:
Thanks for the report. I suspect the issue is the BATT_VOLT_PIN needs to be set to something else but I’m afraid I can’t say what it should be set to… :-(. Maybe @tridge knows…
I think it is a issue with Mission Planner. The flight controller is flashed with copter 3.6.1 and works with the daily build QGroundControl. On Mission Planner I still don’t get any voltage readings. But with QGroundControl I do get voltage readings. Here is a picture of the correct voltage readings on QGroundControl:
