I have a home built quadcopter running Pixhawk 1 and I want to upgrade it to Pixhawk 2. My quad uses the AirbotPower Module (http://ardupilot.org/copter/docs/common-airbotpower-power-module.html) and I’d like to continue using it.
The AirbotPower board uses a 6-pin DF13 cable to connect to the power port on the Pixhawk 1. My Pixhawk 2 came with a new style power cable that has a 6-pin DF13 connector on the other end. I’d like to know if I can use this cable as it is. Can someone verify the wiring? I don’t want to blow up my brand new Pixhawk 2.
Thanks,
Robert
