Hello everyone
I tried for several months to work my Pixhawk unsuccessfully
I can not arm the controller. When I press the switch, the red LED stops flashing and remains on, but the LED of Pixhawk still following blue or green flashing GPS reception there or not even Stabilize mode.
I find it equally impossible to calibrate the ESC, all procedures that I could find on the web or tutorial on YouTube does not. After the second disconnecting the battery the process stops
At first I configured the Pixhawk with Qgroudcontrol, then with MissionPlanner, but whether with one or the other problems persist
On the missionPlanner firware insalled is 3.3.3, the latest ,. I tried with the previous firmware, without changing anything to my problem
Thinking it is the pixhawk was defective I bought a second but the problem is the same with this one
My setup:
Ppixhawk 2 purchased from hobbygaga
power distribution plate with 2 spout (12 and 5 volt) purchased from hobbygaga (http://www.hobbygaga.com/fr-5-en-1-carte-d-amortissement-carte-de-distribution-d-alimentation-5v-12v-bec-courant-voltage-c-p270432.htm) all connected to a 6s lipo battery Turnigy my 16000
Module latest GPS (with Glonass)
telemetry module 433 mhz
Radio control Devo f12e receiver with 12 channels devo
6 Engine Emax 340 KV allimentés in 6S
6 ESC Emax BLHeli 40 amps
Can anyone help me
thank you
