Nice Wimpie! Yes, I found the use of a cheap Flight Controller running Betaflight to be a much easier way to program ESC’s than some of the USB programmers out there.
to connect 4 in 1 esc do i need to change perameters in mission planner ,. my pix arms but no motors work
No, nothing different than single ESC’s. 4in1 accept the same signals. All 4in1’s are is 4 separate ESC’s on 1 board sometimes with a common current shunt.
previous comments say set motor pwm to 0,1 0r 2 my flight controller arms but no motors I appreciate your time . I have been trying all day
Which 4in1 is it? Do the motors run in Mission Planners Motor Test? Attached your Parameter file, let’s have a look.
You can leave the MOT_PWM_TYPE to 0 for now. All ESC’s support that.
hello guys, is there a new web link because i can’t open the web above
thank you very much sir
Does 35a mean 35 a is alloted to each esc or 35a total esc rating?
Each ESC.
Can i use 35A 4 in one esc with 750kv flycat 5010 motor i have attached the thrust chart of motor and the photo of the esc below . I am using pixhawk and 4s 5200mah battery.
https://robu.in/product/25a-2-4s-blheli_32-4-in-1-brushless-esc-for-rc-drone-fpv-racing/?pid=674156 this is the link for esc
If the ESC supports the voltage and current requirements it can be used with any brushless motor.
heyy could you tell me what type of connecter this esc uses?
