Hey, thanks for reading this post.
Details of the build:
Pixhawk 2.1, Copter 3.5 and tried with 3.6 beta
HERE GPS
Tarot X4 frame
T-Motor U7 420KV Motor
Tarot 1855 props
40-Amp T-Motor ESCs
6S 16AH Lumenier LiPo
So I finally got my big quad back in the air yesterday! Most recently I had to shoot it out of a tree last August after it entered a severe yaw spin during an AutoTune.
After two new props and GPS mast, the quad looked airworthy again. So I hovered in stabilize twice to make sure it holds well before entering loiter. Then I loitered a few feet off the ground for about 15 seconds and everything looked fine. Next I sent it about 20 feet or so in the air to see if it continues to behave well. It was a great success! Aside from an altitude drop during yaws, it seemed perfect.
However, when I began to descend the drone began to toilet bowl worse than I have ever seen a drone toilet bowl before. I pulled the throttle down to try to land it before it swung itself over the nearby lake. I managed to crash the quad on the grass and only break one prop and the GPS mast.
I can’t understand how it went from flying nearly perfectly to going full stupid. There are some power lines/transformer maybe 40 feet or so from where I flew… but can those really cause such a bizarre spontaneous toilet bowl like that? Or was it just a bad calibration to begin with?
If pics or anything like that would be helpful, I’ll surely provide them. Any insight any of you could provide would be massively helpful.
