Pixhawk 2.1 pinout doc need to be on the Pixhawk 2.1 page
This pinout diagram, if correct, needs to be on this page:
http://ardupilot.org/copter/docs/common-pixhawk2-overview.html
It does not appear to be on the Proficnc site or anywhere else I could find on the web.
Do you know the pinout for SBUSo y CONS connections?
The SPKT port pinout appears to be incorrect. Pin #1 (denoted by red dot) is the signal pin, Pin #2 is ground, and Pin #3 is 3.3v.
I have looked through image results for Spektrum remote receiver pinouts, and not found any that match the above pinout for SPKT.
Additionally, I just probed my own Pixhawk 2.1, and found Pin #1 to be ~2V (indicative of signal RMS), and Pin #3 to be 3.3V relative to Pin #2.
holy CRAP. THANK YOU FOR THIS. I’ve been searching all over for a pinout diagram. It’s incredible how poorly documented the pixhawk is.
The full pinout for this controller is in its manual below as well as on the cubepilot docs page
https://docs.cubepilot.org/user-guides/autopilot/the-cube-module-overview
Manual
http://www.hex.aero/wp-content/uploads/2016/07/DRS_Pixhawk-2-17th-march-2016.pdf
You can find the details about pinout right here:
https://ardupilot.org/copter/docs/common-thecube-overview.html
Guys,
I have F450 with mini pixhawk v.1 with FS-IA10B. Do you have proper wiring diagram pleas?
This one?
https://docs.px4.io/v1.9.0/en/flight_controller/pixhawk_mini.html
