I’ve been through as many forums and webpages as I think I can handle but I’m getting nowhere.
Have a bit of a frankenstein drone in the making, mostly working but struggling with a few things.
I have the pingrx ADS-B module plugged into Telem2.
915mhz telemetry radio is connected to Telem1, it works and I can connect to the drone and see data through Mission Planner.
I also have a MinimOSD module (to send telemetry to my FPV monitor) and PRM02 (to send telemetry to my controller) connected into Telem1 also, the TX lines on both modules are not connected and RX is connected to the Telem1 TX output as I think it’s supposed to be.
I’m not getting any telemetry data to either the MinimOSD or PRM02.
Second issue, I’ve got external RGB LED’s connected, they’re wired into the I2C port. They work, until the HERE+ GPS Module is plugged in. Once that GPS is plugged in (GPS1) the navigation LED’s switch off and the GPS Module internal LED’s switch on.
Really hoping someone can help its doing my head in bigtime.
Hi Brendan,
I ve got the same problem with the external RGB LED. When my HERE GPS is plugged in, the LED won’t work. Could you find a solution?
As I can see, other people also have this problem:
Hi Brendan,
sorry to hear that. I’m wondering if it’s just a simple problem with the I2C address. Maybe it would help to change the address of the LED-Module? But I don’t even know if the device supports that…
Don’t think it does, I also tried to take it off th I2C bus and use the GPS2 port which had the same result as soon as there HERE+ GPS Module was plugged back into the GPS1 port
As far as I understand, that’s because GPS2 internally uses the same I2C bus as the I2c 2 port. But GPS1 doesn’t, right? So why does a device on GPS1 port affect the LED module on I2C 2? Do you have an idea?
