I’m trying to get the PingRX working on a cube running the latest master (3.7) with the latest beta of MP. I have the PingRX hooked up to the Cons (serial 5) port, and powered off of the servo rail from an external 5v BEC. I’ve set it up in MP as specified in the wiki. I’ve successfully connected a PingRX last summer on a cube running 3.5 on the telem2 port.
Is anyone running a PingRX or Ping2020 with the latest master on a different serial port? Is there anything I need to to in MP to get the nearest aircraft to display on the map? I know some aircraft are in the are as I checked on flightradar24.
