Hello everyone!
I am trying to set up the ping sonar with ArduRover (V4.5.4, flashed on an OrangeCube+). I was able to use a USB2RS232 adapter to verify that the sonar works (firmware version: V3.29). Then I followed this tutorial to configure ardurover and used the appropriate connector to connect the sonar to the serial 2/telem 2 port. However, I am not able to get any data from the sonar in the mission planner. Also, once connected, mission planner shows the following message:
“PreArm: Rangefinder 1: No Data”
I would appreciate any help with this
