I have connected a Ping sonar sensor to my PX4 flight controller via the telemetry port, but the sensor data is not being displayed in Mission Planner or QGroundControl. What steps should I take to troubleshoot and resolve this issue?
I donโt believe you want to use the telemetry port for that. Try the CAP & ADC IN port then set the Mission planner RNGFND1_PIN to one of the ADC ports.
If you canโt find the RNGFND1_PIN parameter, you should change the RNGFND1_TYPE or something similar to your sonar sensor, then refresh the params to see the other ones.
@Vignesh_Karapurkar have you followed this page ?
https://ardupilot.org/copter/docs/common-bluerobotics-ping.html
@bassyreflex he is talking about using an underwater sonar not an analog sonar rangefinder.
