Hi, sure, latest version supports both at the same time, you simply enable CRSF support from the config menu under TOOLS, nothing special needs to be done
Hey @yaapu, fantastic work as always. Are there any builds of your changes patched over on top of stable?
Iām having issues with latest
(its pan/tilt support is broken!). MSP for DJI OSD support + this CRSF Passthrough have been really great otherwise.
Hi, no unfortunately no backports
Is it possible to switch off these OSD messages?
I donāt mean the messages in the Mission Planner, but in the OSD messages text field.
ā¦
CRSF RF mode 1, rate is 156Hz
CRSF: RF mode 2, rate is 155Hz
ā¦
Hi, no but in a well behaving system you should see them when they are useful i.e. when you switch rf mode, if you see them too often your setup is perhaps jumping between modes too much
@yaapu I am a bit late to the party. But yeah I could confirm this issue still exist.
When ARMING_RUDDER
is disabled definitely telemetry wasnāt present, the moment I turned it back to 1 (ArmingOnly) - telemetry came back. This is easy to reproduce on my end.
I have the same exact setup with @VenomFPV
F405 Wing flashed with latest arduplane latest 4.1.0.dev
Crossfire nano and micro tx v2 both running on 4.0.8 firmware
otx 2.3.11 on Taranis X9D+
CRSF TX/RX is connected to UART1
GPS is connected to UART3
Attached is my param.
arming_rudder_disabled_yaapu_telem.param (19.1 KB)
Thanks a lot for the hard work you put into this! Such amazing work.
Thank you for all your effort.
Works great with Mateksys F405 wing, but only on UART3.
Big update: I finally got it all working! Bidirectional WiFi UDP connection to QGroundControl on my Mac and iPhone through my Tango2 to my Matek F405-Wing.
I used this TBS Support articleās howto+firmware to update my wifi module to V1.41 - alpha
and that made the difference.
Hereās my complete setup: In the Crossfire Setup Menu I set the Wifi Module (running V1.41) to UDP On, note the port. Set the Crossfire Nano RX Output 1/2 to CSRF, 3/4 to Mavlink RX/TX. I wired crossfire 1/2 to Serial3
and 3/4 to Serial1
(any other serial should also work). In QGroundControl I added a new Comm Link, UDP, with the Listening Port
noted earlier, and no Target Hosts
added. In parameters I set SERIAL3_PROTOCOL
to RCIN
, RC_OPTIONS
to 256
, and SERIAL1_PROTOCOL
to `MAVLink2. Thatās it. Finally got it.
If you use the default port 14550 for Mavlink and set it in the Wifi module, you donāt need to make any settings in QGC or MP, because these apps will connect automatically.
The default setting of TBS for Mavlink to port 8888 is complete nonsense ā¦
Itās not working on serial3. Very frustrating.
Ok, so it looks like what you are suppose to do here is define BRD_ALT_CONFIG = 1 and then use serial6. Not sure if this affects your other experiments, but without that RCIN is defined as being on an interrupt
The latest ExpressLRS apparently has full CRSF telemetry support. I havenāt gotten it to work with Yaapu telemetry, but I do see the telemetry data in OpenTX with the latest version (RC1, which confusingly is apparently the third release candidate, lol).
āInitially ExpressLRS had very limited telemetry support but with Version 1 RC 1 this changed and full support telemetry was added as optional feature.ā
I was very surprised to see this entry on the Crossfire module today - did I miss something significant during my winter break? Didnāt activate the entry as I wasnāt sure what it would doā¦
You have access to a subset of ArduPilot parameters, the same ones you would see via the OSD
But bear in mind that it really only works on the transmitter itself, the CRSF TX does not have a powerful enough CPU to cope. If you have an OpenTX transmitter you can go to the crossfire menu. Also TBS have released some new AgentX scripts that should work a bit better.
Iām digging into the code because there is a discrepancy in the ExpressLRS documentation. In some sections it says they only support a subset, and in other sections it says they now support all CRSF telemetry. I asked about this in the ExpressLRS Discord group and was told that the documentation Wiki is open to edits by anyone, so that is their explanation for the inconsistency.
The ExpressLRS devs have updated the documentation, to show that they are passing all CRSF telemetry data.
Iām getting 22 telemetry types with ELRS and 23 with Crossfire/Tracer. It seems like the only type that I donāt see in OpenTX when using ELRS is FM/Flight Mode. Yaapu telemetry says No Telemetry.
Iām on 200hz refresh rate with 1:2 telemetry rate and Iām using a TX16S.
thatās cool, I must have a spare R9 kit around, Iāll try it myself
@yaapu Have you run into anyone having late frame rate errors that trigger a fail-safe? I had one recently, and now thereās another post about it. His log has more examples, but Iāll post mine if itās needed too.
