ok, version 4.06 added support for an ardupilot reserved frame id, I have no idea if tracer firmware was updated as well, need to check with TBS, you’ll know if rf mode detection works by looking for messages like CRSF: rf_mode etc
I suppose we can pose the question to Remo but let me test first.
Yeah, I just asked Remo for more info
It doesn’t appear to work, but qq: the TELEMx_FUNCTION in your write-up says 23, which is RCIN… why wouldn’t it be 29 (Crossfire)? Is that not fully supported yet?
edit: It must not be, because if I change to 29, I get no working RC. Odd…
Reporting successful copter build and test
with CUAV pixhack V3x using branch test/crsf_telem_passthrough
TX : Qx7 + opentx 2.3.10 + Crossfire Micro tx v2
Rc : crossfire Nano rx
@vierfuffzig, @andyp1per and I played with DMA on the omnibusf4pro (really need to thank Andy for helping me out on this) and we can state that DMA is a requirement for CRSF to work at full speed.
The MatekF405-Wing suffers the same lack of available DMA streams, if you check
build/MatekF405-Wing/hwdef.h
after running
./waf configure --board MatekF405-Wing
you’ll see that the DMA resolver cannot find a dma stream for any UART except for UART1 (UART2 has the NODMA directive)
// Note: The following peripherals can't be resolved for DMA: ['UART4_RX', 'USART6_RX', 'USART3_RX', 'UART5_RX']
thanks @andyp1per and @yaapu for persistently tracking this down. if i understand this right it might not be easily resolvable though and limit full speed crsf support to a single uart on quite a few boards though…?
@vierfuffzig well yes, at least for F4 an F7 boards, CubeOrange (H743) on SERIAL4 (GPS2) has TX DMA disabled but I get 160Hz no problem whereas on a kakute F7 dma is required on both TX/RX to get 160Hz
hello.
could you build a version for [F35Lightning] board.
Hi all,
I updated the test builds, version 0.9 is available here
This version has better rf mode detection and it’s compatible with the crossfire lua parameters script.
On non DMA uarts telemetry works fine but the crossfire lua script is kind of slow in getting the parameters from ardupilot, not much we can do about this.
I tested it with crossfire fw 3.72 up to 4.08 on a Micro TX V2.
It requires a newer yaapu script, version 1.9.1 beta1, download from here
cheers,
Alex
Hi Alex,
Thanks again so much for your efforts here. These enhancements really do make ArduPilot more fun to fly!
I saw that you now have a “pr” version of the pr in addition to the test one. Is that the one we should be building off of if we’re building ourselves, or would you prefer we stick with the “test” one?
Thanks again so much for everything!
Josh
PS Any word back from Remo on Tracer supporting this enhancement?
Thank you, Alex.
I’ll try it.
Hi Josh,
right now the pr version is identical to the test one, I have distinct branches so I can change the pr one without affecting testing. You can compile either one.
No feedback from Remo about the tracer. Did you ever have success with it?
You should use serial protocol 23 and hopefully get RC + telemetry, use a UART with dma enabled.
Edit: The TRacer manual says it has a single rf mode (up to 15 miles in “rural” environment), and fw versioning is distinct from the TBS legacy one. I’ll need for sure a way to detect tracer vs tbs and change the way I handle rf mode switching
No success.
Can you confirm which UART I should be using for normal CRSF on CubeOrange?
Hi Alex,
I have tested Your last version compiled from Your test branch ( ff56022 ).
I tested it with crossfire fw 3.72 on a Micro TX V2 - yaapu script, version 1.9.1 beta1.
Settings same as at the last test.
Working fine at distances over 1000m.
Just missing the “Air Speed”
Cheers, Markus
Thanks Markus, your feedback is really welcome!
Missing “Air Speed” because you do not have the separate indicator for both groundspeed and airspeed (like when using the MavToPT firmware) correct?
Hi Josh,
Telem1 and Telem2 are fine, don’t use GPS 1 (DMA on RX is disabled), GPS 2 has DMA only on RX but in my testing CRSF works fine @160Hz, so to recap:
- telem 1
- telem 2
- gps 2
Alex
Thats correct. The "Airspeed" was only implemented at the "Plus Version" from Eric
s MavlinkToPassthru.
- 0x50F2 VFR_Heads Up Display
Cheers, Markus
OK, I’ll be able to get that from scripting as soon as the frsky scripting PR gets in.
Telemetry data injected from scripting will work for both passthrough over frsky and over crossfire.
