Hi @Leonardthall, I do not know if this should be a new topic but I did not find anything online. I just upgraded from AC3.6.8 to AC3.6.10 and although everything looks ok I have a strange passthrough telemetry message popping up 2 times as soon as I power the copter: AK09916 reset failed. I tried to go back to 3.6.8 and the message disappears. Am I missing something? Should I worry about this message?
I thank you in advance!
Cheers
Filippo
Please open a bug report on GitHub.
Don’t forget to specify the exact model of the hardware you are using.
The error is benign AFAIK
Hi @LuisVale
thank you for your reply. I will open the bug report. Benign it means that I do not have to worry about right?
Cheers
Filippo
well, I’ve seen it on some boards and nothing bad happened. I believe that the system is trying to enable a sensor that the specific board does not have.
Thank you @LuisVale this makes sense to me, not sure if the Pixhawk 1 has the magnetometer AK09166 on board but I am sure my external compass+gps module has a LIS3MDL compass. I opened the bug report now.
I have been seeing that as well on my Pixhack CUAV v5. It goes away after a couple of minutes and reboots.
Dear @rge99 in my case it does not reboot. I just see the INFO message two times a few seconds after powering the copter but then it does not show anymore and it seems I can arm the copter without problems,
@LuisVale today I was able to do a test flight with the new 3.6.10 version. The copter is flying as usual but it is very interesting because that message I told you yesterday is not registered as a MSG in the dataflash log. It appears only on my TARANIS as passthrough telemetry message.
Yes. It’s not a log message, but only on boot
I’ve added it to the agenda of the weekly dev call so we will definitely discuss it next Tue
I also see this message when booting AP Plane 4.0.3rc2 on Omnibus F4 Pro v3 board - again on my Taranis messages page (Yaapu telem script).
