hi please need a help, opical flow not work PX4FLOW V1.3.1.
my copter f450, pixhawk 1 radiolonk, firmework 3.6.10
with gps work well, i want use optical flow for inside.
after configuration the optical flow and test i can’t fly loiter mode or position hold (disable to switch), althold can’t increse the throttle. stabelize no problem.
https://drive.google.com/open?id=1BOgeDhqxo-nbLObiW9tsoZp7KiewgClQ
test roll and pitch
https://drive.google.com/open?id=1Dq4nYeScnRUC3SOTu5kkhLM_G8rWeYTJ
picture of OF
Do you have a rangefinder? That is required for some modes…
no range finder, no ultrasonic
From the docs:
- As with the PX4Flow sensor a range finder is required to use the sensor for autonomous modes including Loiter and RTL
- FlowHold does not require the use of a rangefinder
i can’t use OF without rangefinder?
can a use baro or flow hold?
You should be able to use FlowHold, I don’t know about the others…
