Hi Ardupilot community,
I am using an MTF-02 optical flow module with a BETAFPV F405. OF is disabled by default for flash savings, but I was able to use custom.ardupilot.org to generate a firmware with optical flow functionality. I’m able to monitor (opt_m_x/y) and see a result.
This would be fine and dandy, but I am also writing a custom mode and locally generating a binary. When I include the extra_hwdef.dat that was generated by the web tool, I return to no opt_m_x/y. What confuses me is that the .bin and .apj are identical between the web tool and my local environment (before the new mode is implemented). After I flash, there are some differences between the .parm’s but nothing that I notice as impactful.
Let me know if you have any suggestions to enable optical flow in my local environment.
