O.K. here is the skinny on my problem. My Solo number 5 one of my test vehicles. Stock cube.
I had Open Solo 2.5rc3 on it and all was good. So I thought I would test the new 3.7 dev on it. I loaded Open Solo 3.0 on the controller and copter. Then loaded 3.7dev on the copter and the 3.6/3.7 firmware on the controller. Controller is good I believe but I am suspicious of the copter. Both Solex and Mission Planner indicate the copter has 1.5.4 on it still. I’m also using Solex 1.8.3. My concern is the firmware on solex says the following
Autopilot:1.5.4 Controller:3.0.0 controller f/w: Opensolo - 4dev-33-g0b3465d Vehicle: 3.0.0 Gimbal:. Is this correct or is my Solo really have 1.5.4 on it. I thought I followed the instruction properly and my vehicle was fly fine on Open Solo although it was initially on 2.5rc3. Do I need to wipe and reload 3.7dev? I’m not doing a damn thing until I here back. As always thank you for all the hard work.
P.S. I did not know the best place to post this.
