I’m using the DO_SET_ROI command in mission planner and trying to get the drone to orient itself so that its side is pointing towards the ROI and not its nose, i.e a 90 degree offset. I haven’t found any way to change this so far, and it’s not as simple as just adding a single offset, as the angle needs to constantly change as the drone flies.
Any ideas how to do this?
Thanks,
Dan
