Recently ive connected a PX4 flow sensor I got off ebay to a pixhawk cube on i2c and enabled it under optical flow only to find it’s not displaying any numbers in the OPT section of status under ground control. When I unplug the flow from the pixhawk and reboot, it displays bad Optical flow like it knows it was connected and working. Could this be a driver or setting I’m missing? How could I go about looking at the output of the ardupilot software to see if there is an error? Thanks.
yeah, it lights up like it should. I checked to make sure it was getting enough power and amps too, everything is good. I’m about to flash it now and see if that is the issue. It’s odd since it’s showing up as working on qgroundcontrol when i test it.
