hey guys setting up a bird here. I’d like to know if I can use the CONS port in the pixhawk cube standard, to run GPS. I have a module but I don’t want to change connectors. I’ve seen people use the CAN1 or CAN2 port for GPS.
If you have a CAN GPS like Here2 or mRo location one, you can use them on CAN ports. Alternatively you can buy CAN node to make your old serial GPS connect on CAN.
