Hey I am experiencing a problem after flashing AC 3.6 RC 9. I am currently developing a computer vision application where I use a Pixhawk mini and a companion computer called Nvidia Jetson Tx2 module (https://bit.ly/2N6L9p3). The way I transmit info between the Pixhawk and the Jetson is via the telemetry port. Up to AC 3.5.7, I can send and receive info to the jetson but after flashing the newer version AC 3.6 RC9, I haven’t been able to make it work. Is there any known issue related to the UART ports?
I have another question.
We are also testing the Kakute f4 v2 as an additional option for a flight controller. The same UART problem/solution applies to that FC? or is there a different issue?
I can’t make it work, even with the suggested baud rate speed. Is the UART’s numbers mixed up?
different issue?
The same problem would have applied.
I can¢t make it work, even with the suggested baud rate speed. Is the UART¢s
numbers mixed up?
I’d suggest trying the lower baud rates.
Sorry - I don’t have a Kakute f4, so I can’t verify - I haven’t heard
of any issues, however.
Yesterday upgraded to RC 9 and it seems like my FC is arming even though “all” pre-arm checks are enabled and there is no fix so arming should be denied.
@RonaldMeza, I’ve added the fix for baudrate rounding into the Copter-3.6 branch, but I’d appreciate it if you could test it on your setup.
I’ve put a fmuv3 binary here: http://uav.tridgell.net/RonaldMeza/copter-beta3.6-uart-fix-test1.apj
please test that at a variety of baudrates and let me know if it fixes the issue for you.
Cheers, Tridge
