OK, setting up a Matek 765 Wing in MP and I’ve gdone the Radio Calibration, and all the indicators respond properly to tx stick inputs. Going to Servo Output and all work except throttle, which does not respond. RCMAP is 1/ail, 2/ele, 3/thr, 4/rud. Checked my Transmitter and it is actually set at TAER, so I re assigned the tx to match the RCMAP settings and everything is jumbled . Not sure where to go from here…Ideas would be appreciated!
You may find it easier to go the other way and re-organize the RCMAP. Nothing saying you have to leave it as AETR, that’s just a default. But you can do either.
Was the plane armed when you tested the throttle output?
Thanks, Allister…I did try resetting RCMAP to match the Tx settings, but that did not work either…we are on the bench setting up right now…not installed in the plane, just looking for correct response in the Servo Output settings…can’t get the throttle channel to move there, but the controlsurface channels are fine??? I now see that SERVO1_FUNCTION, ect 2/3/4…also is in the mix, so I am a bit lost now, not sure what should be changed 1st?
Hey folks, I am facing issues with setting up the Left Throttle and Right throttle on my elevon plane with twin motors. Servo 1 and Servo 2 are setup for Left elevon and Right elevon. Servo 3 and Servo 4 are setup for Left Throttle and Right Throttle. Plane is armed but the Throttle servo bars are not responding to throttle stick. However, when I am setting up just Servo 3 or 4 for Throttle only, the Servo bars are moving, ESC are calibrating and motors are powering up. The issue arises when I setup the left and right throttle on 2 different servo outputs. Someone please help!
