No such file or directory
Hi, I am getting no such file or directory error while trying to build the hwdef.dat file using wsl,ubuntu. I looked into it and found that files in the “module” folder in the cloned repository are not being included. Can anyone help to resolve this error? Did I do something wrong while cloning the repository.
Embedding file bootloader.bin:/home/kala/ap_periph/Tools/bootloaders/F412_LED_bl.bin
[ 29/549] Compiling libraries/AP_Airspeed/AP_Airspeed_UAVCAN.cpp
[ 43/549] Compiling libraries/AP_Baro/AP_Baro_UAVCAN.cpp
[ 74/549] Compiling libraries/AP_BattMonitor/AP_BattMonitor_UAVCAN.cpp
[ 79/549] Compiling libraries/AP_CANManager/AP_SLCANIface.cpp
[ 80/549] Compiling libraries/AP_CANManager/AP_CANTester.cpp
In file included from …/…/libraries/AP_Airspeed/AP_Airspeed_UAVCAN.h:13,
from …/…/libraries/AP_Airspeed/AP_Airspeed_UAVCAN.cpp:1:
…/…/libraries/AP_UAVCAN/AP_UAVCAN.h:23:10: fatal error: uavcan/uavcan.hpp: No such file or directory
23 | #include <uavcan/uavcan.hpp>
compilation terminated.
In file included from …/…/libraries/AP_Baro/AP_Baro_UAVCAN.h:7,
from …/…/libraries/AP_Baro/AP_Baro_UAVCAN.cpp:1:
In file included from …/…/libraries/AP_CANManager/AP_CANTester.h:20,
from …/…/libraries/AP_CANManager/AP_CANTester.cpp:23:
In file included from …/…/libraries/AP_BattMonitor/AP_BattMonitor_UAVCAN.h:6,
from …/…/libraries/AP_BattMonitor/AP_BattMonitor_UAVCAN.cpp:7:
Waf: Leaving directory `/home/kala/ap_periph/build/F412_LED’
Build failed
→ task in ‘objs/AP_Airspeed’ failed (exit status 1):
{task 140342185576928: cxx AP_Airspeed_UAVCAN.cpp → AP_Airspeed_UAVCAN.cpp.0.o}
(run with -v to display more information)
→ task in ‘objs/AP_Baro’ failed (exit status 1):
{task 140342185514192: cxx AP_Baro_UAVCAN.cpp → AP_Baro_UAVCAN.cpp.0.o}
→ task in ‘objs/AP_CANManager’ failed (exit status 1):
{task 140342185357408: cxx AP_CANTester.cpp → AP_CANTester.cpp.0.o}
→ task in ‘objs/AP_BattMonitor’ failed (exit status 1):
{task 140342185351360: cxx AP_BattMonitor_UAVCAN.cpp → AP_BattMonitor_UAVCAN.cpp.0.o}
Did you do:
git submodule update --init --recursive
yes, I did that when cloning the repository
Do it again, something went wrong.
Done again… but getting the same error
Used ./waf configure --board boardname and ./waf AP_Periph to build the hwdef.dat file.
Here is the hwdef.dat file written for uavcan battery info. please once check whether it is correct or not
New Text Document.txt (2.0 KB)
