hi im trying to set up tilt rotors on a freeman 2300 vtol with an orange cube and I’m having trouble getting a servo output to the tilt rotors.
in setup menu on mission planner the servo output for these remains at zero and when powered they do not fire up
Hi, I am having the same problem. Can someone please give me hint to resolve it?
best regards!
same here. I figured out that “Tiltmotors Front” works for me.
But “Tiltmotors Rear”, “Tiltmotor Front Left”, “Tiltmotor Front Right”, “Tiltmotor Rear Left” and “Tiltmotor Rear Right” do not work at all.
Greetings
David
found the answer.
Look here:
Regards
David
First of all, I can confirm that it now works. At least I now have a signal at the servo outputs.
Thank you very much David. You have saved me a lot of time!
Regards
Frieder
