Hi
I am using a CubePilot Orange with a Here 4 GPS with the latest firmware and DroneCAN.
I continually get ‘GPS: No GPS’ in the mission planner.
I have tried to swap the GPS out for two other Here 4 GPSes (1 Here4 Blue and 1 Here 4) with no luck and the original GPS was working fine until I messed around with the NODE ID and then it stopped working.
This is the parameters that I used in ardupilot when the GPS was working:
14-06-2024 Parameters.param (18.4 KB)
And these are the GPS parameters (I do not have the parameters from when the GPS was working):
GPS Parameters (Bad).param (1.8 KB)
Any help would be much appreciated.
Thank you
Finley
EDIT: Amended the fact I am trying to use DroneCAN
EDIT2: I have tried this now with 4 different GPSes, 3 Different Cubepilot FCs and 2 Different laptops with mission planner and I am still unable to connect to the GPS once I have changed the NODE ID for the here 4 GPS.
