hi i have a problem with my gps neo 3 pro cuz after i plug it in can port, and after changing paramerter like can d1 d2 protocol, and can p1 p2 drivers to 1, gps type to 9 and ntf led to 231 i still have no gps
Heve you set all these?
There are also some other things to note on the wiki
You should read through the wiki once more and look for anything you might have missed.
https://ardupilot.org/copter/docs/common-cuav-neo-3-pro.html
is that GPS working good? try to replace it with another.
if you have tried these
CAN_P1_DRIVER = 1
CAN_D1_PROTOCOL =1
CAN_P2_RIVER = 1
CAN_D2_PROTOCOL =1
GPS_TYPE = 9
yep … i did all of that but nothing changed … until i flashed the cuav v6x and setup it again … still dont know what was the cause of the problem … but anyway thanks
