Hello, On one of the copters with Cube black, 4.0.4 firmware and Mauch sensors, the current readings are always zero. The voltage readings are however correct. Even when I change try to change the A/V values or try to manually enter the measured current values, the current readings is zero.
So I installed the 3.6.12 version and now I am able to see the readings again. Any suggestions?
Thanks
