Hi every one!
I have a trubble with connection between receiver and motors in quadcopter.
When I test motors via MissionPlanner it works. I can run all motors with mission planner.
I also can test ESC (receiver) via MissionPlanner. In MissionPlanner I can see that receiver also works.
But I cannot run motors via receiver without MissionPlanner. What should I do for remote control my quadcopter with receiver?
I would start by eliminating the BEC connections from each ESC and plug in the power module that I see is disconnected. Just use a needle/pin to unclip and pull the middle red wire from each ESC plug.
Just the middle red wire should be ok. I say unclip it because someday you may want to put it back for another purpose. Some people cut the wire.
The red wire from each ESC is providing 5V to the Flight computer. This power could have noise and could affect the FC. You will get clean power from the power module via the main flight battery.
When you have the USB connected, your computer is powering the FC.
Sounds like to me is that the receiver is not being powered except when the USB cable is attached.
Clipping the red wire is not going to change anything as the motors don’t work at all unless the computer is connected. The red wire just fixes clean power issue.
You should be able to power the motors directly off the receiver as a test.
I don’t know looks like dean connector to me. Anyway if the jumper plug is not installed is there still power to RCin side? I’m not an APM2 guy. With no power on the RCin side the receiver won’t work.
If you unplug your USB cable, does the receiver still have power?
You have a red & black wires from the receiver going to an aux plug on the flight controller. I’m not sure about this. If you use a regular servo cable from the receiver to the input side of the flight controller, it should get power. Can you move the red & black wires to the input side or use a 3 conductor servo cable?
I see you have single wires from the receiver to the flight controller. I think this should be ok. Just make sure the receiver is powered when the USB is not connected.
Arducopter has failsafes that will not let you arm unless certain minimum requirements are met. One is a high quality GPS lock. Another is that your power module voltage sensor is calibrated in Mission Planner so it does not failsafe on what it thinks is a low battery. You need watch the HUD in Mission Planner and see if you are getting a warning or use your logging to view the logs and see if there is a failsafe error in the logs.
There are many different failsafes and you must satisfy all of them before it will arm.
Replace 1 cable from your receiver channels with a 3-conductor servo cable. This should power your receiver from the flight controller.
If this does not work, you will need another 5v power source. My flight controller was outputting only 4.8V but was enough for my receiver to work. Your receiver may be voltage sensitive. Check the voltage level coming out of the flight controller.
If you do not have a power distribution block with a Battery Elimination Circuit (BEC), you can get 5v from one of your ESCs where you have already removed the center red wire. The trick will be to get a negative ground. Either leave the 3-conductor servo cable in place or split one of the black ground wires from your ESC.
A volt meter will be very helpful for you to figure out the problem. Check the voltage before and after unplugging USB.
