I am looking at integrating a new driver for sensor data / telemetry into ardupilot pixhawk6x specifically Arduplane over SPI. I have been looking at examples (barometer) and also read following the link: Sensor Drivers — Dev documentation
workflow between what I have gathered/research seems a bit inconsistent which is understandable.
I seen some areas for example call for AP_HAL::Device and other AP_HAL::SPIDevice?
Believe the “Device” call is an abstraction layer for devices? (I2C, SPI…) where “SPIDevice” is only pertinent too obviously SPI…
Do I need to do the frontend vs backend split as mentioned in that above link?
I guess I am looking for some further direction/clarity on how I should go about setting this all up at a high level.
Is there is a prime example (over others) layed out in software that can be suggested to follow as a blueprint/setup for integrating?
Appreciate yall.
