Excellent work Pete - thanks.
Iām already using those features as they appear
Hi Aleksandr,
I believe you would set the FREQ to the no-load ICE frequency, and the FREQ and BW with scale up as the RPM increases.
You can use whatever bandwidth works best, provided itās not so wide it affects the low ācontrolā frequencies or causes lag in attitude control. This is one of the great aspects of the Filter Review Tool - you can find and set exactly what is required to be effective.
I would trust the results of the filter tool - itās perfectly OK to deviate from the BW = 1/2 FREQ rule.
Thank you for the quick and accurate response! I use a very stable aircraft for beginners, the developers of this aircraft have made it so that if you make mistakes in controlling the aircraft, it will fly right if you remove your hands from the RC transmitter.
In the documentation of the ardupilot it is written that low-pass filters create a large phase delay, but the enabling of the Harmonic Notch Filters allow targeting the noise generated by the motors.
A low-pass filter is more effective in an area where ICE is idling, but this mode of operation is used on the ground, and in flight, ICE speeds are used above average and up to maximum values, this is what I call the work area. For the work area, I think the use of Harmonic Notch Filters is relevant
As I saw from the graphs of the tool, the INS_HNTCH_BW parameter does not have much effect on the phase delay. However, I think that the great inertia of my beginner aircraft will not be able to sense this phase delay, because electrical processes are faster than mechanical processes
I hope that the real flights of my aircraft and the analysis of the recording of lOG files will answer all questions and doubts.
In working with the tool, the video of Andrew Tridgell helped me Welcome and Systems Update Andrew Tridgell - YouTube Timestamp 40:34
I have pushed some updates to better deal with gaps in logging over the past few days. I would only expect issues with raw sensor logging, you might now see gaps in the spectogram like this:
If you have lots then the logging is not keeping up, you could try increasing your log buffer size, or going back to batch logging.
Excellent tool! Is there a way to operate it offline (w/o internet connection)?
No sorry. You can host it locally but it still needs to grab the packages, you could download them locally and point it to them rather than the online version, but it would be a little involved.
Thanks a lot, can you tell me maybe the packages involved? I will try to do it.
You need plotly, math and require, there included here:
And fft which is included here:
You should more or less be able to download those and put in the local path.
Seems broken this morning
I have been pushing changes, it should still work, it just needs that hard reload. Shift + F5
on windows (chrome).
Can you test it with filters on both IMU 1 and 2, ESC telemetry, one notch per engine? That configuration was causing me problems last week.
That should work, can you explain what you were trying exactly? A example log and configuration would help me debug.
Control+Shift+R worked to reload the page completely - no amount of reboots or anything else helped.
Sorry its so annoying, its because were not really deploying properly which in turn is because I donāt really know what Iām doing with web development. If we were to deploy with a tool it would do ācache bustingā for us by changing the file names so browsers are forced to grab the latest version.
Pete you have done an excellent job,brilliant in fact but you are so honest and only want the best thank you for this amazing tool
Hello friends!
Please help with setting up the filters. The more I try to configure them, the worse it gets. Most likely, I misunderstand the configuration methodology. Iām trying to make the postfilter and estimation filtr as similar as possibleā¦ This is probably wrong. My flight file:
Please help set up, and give small comments on what needed to be done. This will help me in the future when setting up. In advance, thank you very much! Hereās my configuration: frame Tarot 690, props 13ā', motors 4215 650 kV, CubeOrange+, Here4, power 6s, esc FLYCOLOR RAPTOR5 45A BLHeli-32 3-6S
RPM is about 4200 when my hexa takes off.
