New Cube orange + Color difference
Hey Guys received a new batch of cube orange+ as attached Image, looks a dark orange color with metallic paint finish. And this throws a error - Configuration error: fix problem then reboot.
please help.
If it is a configuration error, I suggest you reset all parameters to default, load ArduCopter 4.4.4 and follow
Methodically tune (almost) any multicopter using ArduCopter 4.4.x
If you configure it properly the problem will be fixed.
Understood, Can’t it work with 4.3.x Firmware?
Probably not, it is a new product. Look at the release notes to see which version added support for it. You need the + version the non + version will NOT work.
OH, BTW that guide is also valid for ArduCopter 4.3.x
Hey Lucas,
do you know what IMU is used in new metallic cube + version coz. when i chceked it shows 59.
Even in latest 4.4.4
Go to the cube manufacturer website. They have a differences overview
