@Tarek-H Just like @PittRBM stated, the H_YAW_SCALER sets the mixing for yaw control and uses differential cyclic to control yaw. So you don’t want that in your case and that is why I am telling you to set it to zero. I look forward to hearing more about your project.
@PittRBM Thanks for posting!! Hope to see you flying your synchropter soon!
@bnsgeyer Hello , I managed to adapt the ardupilot on our coaxial helicopter, I took the time to understand the code and the AP_MOTORS library, I use the H_DUAL_MODE = 3 ( named HELI_DUAL_MODE_COAXIAL) to refer to the coax_heli , i add also cyclic angle limitation with _cyclic_max parameter exactly the same already programmed in the single copter .
For the moment it is flying well but there is still work to be done in pid, in the log there is some offset between the setpoint and the measurement,
I have a Yaw imbalance% message that I have to solve , maybe because of the slight oscillation of the yaw control around the target .
@hybrid-guy this is about Sprite Vehicule ? have you solved the issue ?
I made a small modification on the software specific to my drone my work is not finished yet , but this in ardupilot dual helicopter frame ( frame class 11) , Sprite Vehicule is not Coaxial Helicopter , it is Coaxial Coper !
@bnsgeyer
I must specify that we have designed a rotor protection, a kind of carbon cap (700 gram), protects the blades in contact with the wall or if the uav flip itself on its side , but add a little inertia in the movement,
I discovered that the parameter ATC_HOVR_ROL_TRM was 300 i changed to 0 now
I’m trying to improve PID specially : ATC_RAT_RLL_ILMI ,ATC_RAT_PIT_ILMI , IMAX ,to use integral in Hover ,
For the Yaw imbalance i know we can remove this message but i need to solve this issue , i use external gouvernor i need to add rpm sensor to check speed of the two rotor .
@Tarek-H It doesn’t appear that you set up your collective range for the swash plate using the H_COL_MIN and H_COL_MAX. Also all of your servo trims are still 1500. Is your swashplate mechanical set up perfect that you have completely level swashplates? If not you need to follow the wiki on how to set up the swashplate
Looking at your tuning, it appears that you were able to get 0.11 out of the P gain but you didn’t set up the VFF gains. Any reason why you didn’t set up the VFF gains first. For helicopters they are the most important to set up. These are just my initial impressions looking at the parameter file. I will look at your data today sometime and get back to you.
@bnsgeyer for the swashplate a mechanical adjustment method is used, all servos at 1500 the swashplate is level and the blades are adjusted at an incidence of 5° ,at this angle from the ground he won’t take off, i keep the same mechanical setting used for our software but i know it must be 0° now , i will change it an see .
the servos limit is H_COL_MIN and H_COL_MAX ,i kept [1250 -1750 ] is enough, it can not reach the mechanical limit of the swashplates or blade stall angle .
and about VFF gains thank you ,I really haven’t seen it, i need to read well the wiki and set up this parameter.
What is the collective blade pitch at H_COL_MAX and H_COL_MIN? Also be sure that you set the H_COL_MID properly. It should be set to 0 deg blade pitch or the blade pitch that produces zero thrust.
Also please give me access to your log files. It is saying I need permission.
The collective blade pitch min max [-5° 11° ] , i will set H_COL_MID to have 0° blade pitch ,and set the IM_STB_COL_ for Stablize mode .
for the Log files i changed permission ,you should access now
@Tarek-H You will have to provide a log with FAST ATTITUDE and PID checked in the LOG_BITMASK parameter in addition to what already is checked. This will provide more information to access whether you have to use the Harmonic notch to remove noise from the control signals and allow the PID signals to be seen. Please conduct the flight in stabilize mode or Altitude Hold. Make quick 20-30 deg attitude changes in pitch and roll. Then make quick 20-30 deg heading changes. It will help me assess whether you have the FF set properly.
About PID there is a set point overshoot in angle control , i think i need to reduce a little P RATE , and what about ATC ANGLE P ! I kept the default values but there is not a lot informations how tuning it manualy !
@bnsgeyer Hi,i am making a coaxial helicopter as you descripted.but i use the h3-120 swashplate .my coaxial helicopter swashplates ganged and mechanically mixed.they have the same col pitch and cyclic pitch.i use the helicopter frame.i set the below esc as heli-rsc(Fixed speed 50% throttle ,CW) and the upper esc as motor 4 (tail esc ,set h_tail_type 4:DirectDrive FixedPitch CCW). in my real flight,my uav cannot keep its heading ,it rotate quickly,can you give me some advice to solve this problem ,thanks. co_heli.param (16.3 KB)
So how do you control yaw axis if the collectives are the same on the upper and lower rotor?
why are you using the tail rotor output to control the speed of the upper motor. that should be the same speed as the lower rotor so you could use heli-rsc output for that motor as well. use an ESC that has a governor for both motors
yes,i uses differential rotor speed to control yaw.could you tell how to have collective and cyclic compensation disabled? is there a parm to close it ,i searched key word in parms,but i can‘t find it .
