I am trying to use Neopixel LEDs on my rover, without much success.
I have set the NTF_LED_TYPES to include neopixel (a value of 257)
SERVO5_Function is set to Neopixel1
the length is also set, and it should be mirroring the output of the onboard led, yet I am getting zero output at all
In previous forum posts there has been talk about setting pwm groups, however, as fair as I can tell, this is a depreciated feature as the BRD_GROUPS (or whatever the actual name is) parameter no longer exists.
I have tested that the output does in fact work with a PWM out signal that I measured on an oscilloscope. I also used said scope to view what the actual neopixel signal should look like from a raspberry pi pico.
If any other information is needed for further diagnostics, please let me know.
