Hello , i’m new to the hobby and forum, and trying to calibrate my radio with mission planner on initial setup. It’s the first build i am into and I cannot understand why , but reveiver and transmitter (fly sky FSI6 and FS IA6B) seem bined, as on the receiver I have steady red light.(Also tried re binding again just to be sure). So power arrives to receiver and it seemes binded as I also see battery status of the receveir on the transmitter.
However when I open radio calibration the bars are not green but simply gray, and even if I press radio calibration and move the sticks nothing changes.
Hello I am using a Pixhawk ( the grey model ) and the receiver is connected to the Pixhawk, with a 3 pin cable.
It should be plugged correctly because the receiver receives power , but apparently Pixhawk doesn’t receive signal.
Thanks again
I’ve also sent some pictures that show wiring on the receiver and on the autopilot.
