I have recently built a 50cm Quadcopter which seems to fly basically ok. The flight log however shows NaN in DsAlt. Is there any significance in this ?
Log File C:\Users\Douglas\AppData\Local\Temp\tmp138.tmp.log
Size (kb) 12526.9814453125
No of lines 148162
Duration 0:07:27
Vehicletype ArduCopter
Firmware Version V3.6.10
Firmware Hash 1c04a91e
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (11.81%)
Max mag field length (950.60) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_BATT
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.24, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = GOOD - Motor channel averages = [1584, 1633, 1625, 1623]
Average motor output = 1616
Difference between min and max motor averages = 49
Test: NaNs = FAIL - Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = FAIL - ‘THR_MIN’ not found
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
