Multiple copters but both micro-ros-agents creating two /ap nodes
Hi all,
My setup is: ros2 Humble + Gazebo Harmonic + Ardupilot + Mavros.
I created two ardupilot_sitl instances to simulate two copters in Gazebo. When it comes to micro-ros-agents, they both create two nodes with same name /ap. I could observe the following:
  1. In ardupilot/libraries/AP_DDS/AP_DDS_config.h, we have
    #ifndef AP_DDS_PARTICIPANT_NAME
    #define AP_DDS_PARTICIPANT_NAME “ap”
    #endif
  2. In ardupilot/libraries/AP_DDS/AP_DDS_Client.cpp, we have
    bool AP_DDS_Client::create()
    WITH_SEMAPHORE(csem);
    // Participant
    const uxrObjectId participant_id = {
    .id = 0x01,
    .type = UXR_PARTICIPANT_ID
    const char* participant_name = AP_DDS_PARTICIPANT_NAME;
So, is it hard coded? Can’t we have two namespaces to create two nodes such as /drone_1/ap and /drone_2/ap?
Thank you.
I’m facing the same issue for my multiagent simulation setup. Also micro-ROS-Agent doesn’t support namespacing yet A way to set a ROS namespace in the Agent · Issue #126 · micro-ROS/micro-ROS-Agent · GitHub.
Related issue: Not possible to do multiagent simulation with external odometry · Issue #140 · ArduPilot/ardupilot_gazebo · GitHub
I am also facing the same problem. PX4 has this target_system property to allow for controlling the desired drone rather than all of them. The issue I am facing is services are arming all drones, and send the same way points. I want to send different commands to the different drones. NeitherROS_DOMAIN_ID nor DDS_DOMAIN_ID seems to work. I also tried remapping the topic names from micro_ros but also does not work. Is there any such functionality in Ardupilot or any suggestions for how to proceed? Multi-Vehicle Simulation with ROS 2 | PX4 Guide (v1.15)
I still managed to run multiple drones and control each of them individually but what I couldn’t get working due to all of them having the same namespace is passing each one its own external odometry as they currently all listen to the same /ap/tf topic.
@PESHALA24, @princealy did you manage to make any progress with this?
This was fixed in AP_DDS: Add namespace config for multi vehicle support by snktshrma · Pull Request #32510 · ArduPilot/ardupilot · GitHub by @snktshrma. ardupilot_gz should have full multiagent support now: feat: Multiagent functionality by TannerGilbert · Pull Request #67 · ArduPilot/ardupilot_gz · GitHub
