neither do I, your GPS not being detected could be serial port config hanged, you should check that you still have a serial port with protocol 5
yes, it’s good, connect the caddyx, and fingers crossed
unfortunately no osd
Is Plane supported? I compiled your test branch and loaded it onto my Kakute F7, but I don’t see any of the MSP_OSD* parameters in mission planner…
Should work please double check you used the correct branch test/msp, check if ardupilot/libraries/AP_MSP/* exists
You’re right, I forgot to checkout the test branch
I get a compile error now:
In file included from …/…/libraries/AP_OpticalFlow/OpticalFlow.h:143:0,
from …/…/libraries/AP_OpticalFlow/AP_OpticalFlow.h:4,
from …/…/libraries/AP_MSP/AP_MSP.cpp:21:
…/…/libraries/AP_OpticalFlow/OpticalFlow_backend.h:42:35: error: ‘msp_opflow_sensor_t’ does not name a type
virtual void handle_msp(const msp_opflow_sensor_t &pkt) {}
you’re right, compile for kakute f7 fails. I think the problem is the kakute has a lot of disabled features, let me check it out
Thanks, much appreciated. The Kakute F7 HDV seems to be one of the more popular boards to use with the DJI goggles because of the dedicated port.
:schläfrig: still not
ok, our only way to know whats going on is capture traffic when it’s connected to betaflight, we need the hardware to do it, we might be able to do it with 2 ftdi adapters and a little luck and soldering or better you’d need a logic analyzer to capture the traffic on tx and rx lines
ok, pull the sources and should compile fine!
I have the very same one, should work just fine!
That worked great, thanks!
Alex is there any end to your talent
i will give it a go later on tonight
Thanks Colin
Yeah we need testing, there will be a new version soon with a couple more osd items. Let me know if your board is not listed yet
sometimes ordered that
