with a lot of dust on it
We can do 2 things with it:
- verify that serial traffic is coming out from the serial port while my firmware is running
- check if the caddyx needs some special handling
download https://github.com/whitestone-no/open-serial-port-monitor/releases
Connect the FTDI and identify the COM port (from windows device manager).
Connect the FTDI GND to you flightcontroller GND and FTDI RX to flightcontroller TX.
Launch the serial monitor, select the correct com port and connect to it, you should see traffic flowing
next we’ll try to dump the traffic from the caddyx
Connect the caddyx TX and GND to the FTDI RX and GND.
Launch the serial monitor, select the correct com port and connect to it with the caddyx OFF.
In the received data window you should see no traffic.
Turn on the caddyx and hopefully we’ll see if it’s requesting anything special.
fingers crossed
I’ll try tomorrow and do my best
In a day or two I will be ready to test on a quadcopter with PX4. Can you please add a binary for that?
@yaapu
Hi, I uploaded the binary for target Pixhawk4,
cheers,
Alex
I guess I have the wrong board for that binary?
Found device: PX4 FMU V2
Connected to bootloader:
Version: 4
Board ID: 9
Flash size: 2080768
Downloading firmware…
From: C:/Users/Robert Silvers/Desktop/arducopter.apj
Download complete
Downloaded firmware board id does not match hardware board id: 50 != 9
Image load failed
Upgrade cancelled
Hi, your board is being detected as an fmuv2 hardware id 9 without the 2MB flash limit.
It’s like a regular Pixhawk1 and should use that target IMO, I’ll build it.
Alex
Edit: it’s up
"Hi, your board is being detected as an fmuv2 hardware id 9 without the 2MB flash limit.
I tried it and I can no longer get GPS to see satellites. It’s a BN-880 and worked 10 minutes before the reflash. I do see the compass working.
I then put 4.0.3 official back on, and immediately had 13 satellites So some issue with that binary for my board…
I went into Qgroundcontrol and selected Pixhawk 1 (not 1M) and Official 4.0.3 and that worked.
If that is what you built, I am not sure what the issue is.
cool Klaus, but hey the f405 CTR is the wrong port for it’s not outputting MSP???
Can you cut and paste the caddyx RAW data left panel in a text file and attach it?
btw great job, thanks
the other panel, the one with the hexadecimal numbers right below “raw data”, thanks
…the data you captured from the caddyx was right after turning it on correct?
thanks Klaus, now we have to understand why your matek is not outputting MSP. The captured data should be similar to the caddyx one with a bunch of $M<…
SERIAL2_BAUD must be 115
Klaus, you can have only 1 serial port set to protocol 30 and BAUD for that port must be 115
