Mine is v2 googles, technically shouldn’t make a difference as it’s same as v1.
If your betaflight osd is working. Would you be happy to share the settings , I will load betaflight on f405 wing and give it a go one more time.
If my airunit is defective I,ll get replaced.
Im using now crossfire micro tx and nano rx and Ardupilot 4.2 on. Matek 405
I see only 99 or 0 for rssi in dji osd.
My setup rssi type=3
Serial protocol 33.
With these setting i had working rssi with express lrs…BUT now with crossfire its not working.
Pls help
Is it possible to use msp osd on 4.0.9? Thats the last stable release where Ekf2 were supported for F4 limited boards like f405.
Im little but afraid of using a custom build FW which necessary for ekf2 in case of a F405wing
MSP OSD works fine in arduplane firmware 4.1.2 stable ,Only one thing that the AMP and walt sometimes stuck which means it refresh very slow ,please check the left Corner of the video。This is more likely to occur when the signal is weak, and then the signal becomes strong.Is there any way to fix this problem @yaapu
hard ware:F765 WING.
have you try to reduce serial rate?can that be fix the issue?I want to try lowering the refresh rate for some useless data but I don t knowh how to reduce those parameters。If it is with the DJI system itself, I won’t try it anymore
