I have a pixhawk 2.1 that will not spin up the motors.
When I first turn it on, all the lights are good, but the motors beep every second.
When I push the safety switch it gives a musical tone then when armed, they wont spin.
Anyone know a solution to this problem, or need more information.
Just to verify the drone is basically silent after you press the safety switch? Have you tried to do an esc calibration? You could try the all at once method. Here is a video link. https://www.youtube.com/watch?v=gYoknRObfOg remember to take the props off!
My guess is that the pwm output range to the ESCs doesn’t match the ESCs for some reason. I would have expected Shawn’s suggestion to do an ESC calibration woudl resolve this but some ESCs can’t be calibrated. It’s also possible (perhaps likely) that a parameter change has messed up the output range being sent.
I think if a dataflash log could be posted here we might figure it out.
