I couldn’t insert a video of the drone, but the issue is that on arming, the motors spin then immediately stop, even though I command full throttle, and it stays armed after that until either it times out after 15 seconds of minimum throttle, land detector triggers it to disarms, or I manually disarm it. It doesn’t respond to stick movements(roll, pitch, yaw). I have some various .tlogs from various flight attempts(I don’t have telemetry radio or wifi, I just connected with usb while I spun the motors up). I think it might be an issue on the esc end(I use 30a simonk escs). Also, I have no power module, you can see one but the cable doesn’t work(One day I pulled it too hard.) Also, there are gps glitches, but they clear quickly and don’t appear to be the issue. 2021-11-21 16-01-11.tlog (205.1 KB) 2021-11-21 16-03-37.tlog (554.6 KB) 2021-11-21 16-17-01.tlog (383.9 KB) 2021-11-21 16-22-00.tlog (203.8 KB) 2021-11-21 16-24-59.tlog (641.5 KB)
My question is why is this disarming, and what should I do? thanks for reading this.
I have discovered one more thing. When I disconnect usb, it didn’t even start. The pixhawk is only being powered by the 5v bec in the esc, so the esc is the culprit. I can get some new ones and a power module and maybe it will work? I guess I will use digital escs, so how would you wire them to the pixhawk?
I would like to put an update here. The ESCs broke, but luckily we are going to get an replacement. Meanwhile, I am getting it to arm, and I am analayzing the PWM outs and they are working fine. So the issue is on the esc end. Thank everybody for helping me.
I guess I want to make an update. Replacements came and I returned them. So I am now using digital 4 in 1 escs. Tomorrow I will create a new topic and ask the moderators to close this thread.
