I set up an S500 quadcopter with a Pixhawk 1 controller. I initially set it up with PX4 and it was working very well. Now I loaded Arducopter 3.6.10 and have everything set up and calibrated, but I’m seeing unexpected behavior with the throttle. In both motor test in Misison Planner and with the RC controller I cannot get the motors to start spinning until around 60% throttle. I’m in stabilized flight mode.
I think this is what the PILOT_THR_BHV parameter controls, but it was at the default value of zero, which should use the full range. I set it to 6 (and 7, just to see if it made a difference), but I see the same behavior.
Any ideas?
