Im using pixhawk mini, while trying to perform motor test, motor a won
t spin, all motors are working, servo1 to 4 are set from 33 to 36.
Please help…
Thx
Please help…
Thx
Are you using dshot or pwm? Have you set the motor spin min and motor spin arm values? If the motor won’t spin, how do you know it’s working?
Hi
Using pwm,didnt set the motor spin min and motor spin arm values-what should i set?
I know the motor is working cause i pluggud it to another port and it worked…
You should probably go over the whole guide, but 2.14 will answer your specific questions.
well, it didnt help :( i also tried to calibrate ESC
s… still the same
