Hey everyone,
I’m running into a bit of a problem with my ArduPilot setup. I keep getting a “Motor Not Responding” error, and I’m not sure what’s causing it or how to fix it. When I was searching about this I came across to these resources/articles Motors are not responding to transmitter's command what is uipath and as per them I tried the following.
Here’s what I’ve checked so far:
- Connections: All the wiring seems to be in place, and I’ve double-checked the motor connections to the flight controller.
- Calibration: I’ve tried recalibrating the ESCs and motors, but the issue persists.
- Firmware: I’m running the latest firmware version, and I’ve tried a firmware refresh to see if that would help.
- Flight Modes: The issue occurs regardless of the flight mode I’m in.
Has anyone experienced this before? Any suggestions on what else I should check or try? I’d really appreciate any help or tips you might have.
Thanks in advance!
Best Regards,
