Trying to run an autotune of my shyhunter but when i switch into autotune from FBWA the motor cuts out. It will restart when switched back to FBWA. Has anyone got any ideas what this could be.
Running on a pixhawk cube black flashed to the latest version through mission planner.
RC transmitter switch config error, or check all your RC Options params for a conflict.
EDIT: I’ll check the log
RC channel 6 is your problem, it’s set as both Flight Mode channel and Emergency stop via RC6_OPTION,31
Move the estop function to another channel and test on the ground before flying.
